Abgeschickt von Marco am 30 Januar, 2002 um 15:32:20
Antwort auf: Re: 1100 swingarm on r 80 frame von Hamburg am 18 Januar, 2002 um 22:20:22:
Hi Hamburg,
I'm really going to weld a LARGE plate on the cardan surface. Before doing it of course I'll bring to a friend of mine who is an aluminium specialist to check exactely the composition of the material before proceeding to weld.
This configuration will allow a smooth travel of the rear arm. Otherwise I should mount the shock in the middle moving battery and maybe filter unit.
I'll give you detailed information after I'll have done it.
Ciao
Marco
