Abgeschickt von Joerg am 17 Januar, 2005 um 09:43:22:
Antwort auf: Re: Eieiei ... von ~Clemens am 17 Januar, 2005 um 09:40:51:
Hi
: : Stimmt so nicht. Ein offener Rotor (haeufigste Fehlerquelle) kann dafuer sorgen, dass die Lampe glimmt.
: Wie das, Joerg?
: Wo soll der Strom denn lang fließen, wenn die Wicklung unterbrochen ist?
"If an open rotor or, in some cases, a bad voltage regulator, were the cause [...], the only path the lamp current would have to ground would be through the ground terminal of the regulator. It would be deprived of its normal path through the rotor. The lamp would likely glow rather dimly."
Muhgruss,
