Abgeschickt von Niels Hansen am 08 Februar, 2004 um 15:58:13
Antwort auf: Re: compression r75/5 von Clemens am 08 Februar, 2004 um 15:32:47:
Thank you for the swift reply! I´we never heard of anyone bursting a main block; but it´s definetly worth paying attention to it - it would be quite the anti climax :-)
Do you know whether they broke during low rew pull, or at max rew? My plan was to increase displacement (the engine is in dire need of an overhaul anyway; 80psi left bank, 120psi right bank), increase compression to app. 1:10,5 (by the way, how do you measure this?) and then detune the engine a bit by using a touring cam. In short I want more low end torque, peak effect is not in my interrest.
Thanks
Niels
Niels
