Abgeschickt von oez am 19 Februar, 2004 um 22:29:17:
Antwort auf: Max bore cylinders R60/6- R75/6 von Ulrik Holm am 19 Februar, 2004 um 22:10:48:
: Hello alle!
: Is it possible to rebore the R60/6 and r75/6 cylinders to a piston size of 94mm and then use the 1000ccm pistons. I donīt know of anyone who has done it - but is it possible, will it work? Or will the cast iron sleeve simply be too thin?
: Thanx Ulrik
hi ulrik,
as far as i know it isn`t possible.. the cheaper way is using (used) 1000cc nikasil cylinders..
regards
oez
