Abgeschickt von Ulrik Holm am 26 Februar, 2004 um 22:15:41:
Hello..
Is it possible fitting 1000cc cylinders on /6 models. I mean, are the hole in the main block big enough to fit the bottom of the cylinders?
regards Ulrik
Text: : Hello.. : Is it possible fitting 1000cc cylinders on /6 models. I mean, are the hole in the main block big enough to fit the bottom of the cylinders? : regards Ulrik
Optionale URL: Link Titel: Optionale Bild-URL:
