Abgeschickt von hansen am 18 April, 2006 um 14:37:45:
Antwort auf: HELP FOR KARDAN BEARINGS von almabir am 18 April, 2006 um 11:36:59:
Hi Alberto
if you're talking about the bearings in the joints of the drive shaft: indeed, BMW does not supply them separately. The only way to get them replaced is to look for a company specializing in drive shaft rebuild & repair, e.g. for agriculture or construction machinery. If you can't find one you will have to buy a complete drive shaft.
Good luck
drive shaft: http://www.realoem.com/bmw/showparts.do?model=0481&mospid=47933&btnr=26_0115&hg=26&fg=05
swing arm:
http://www.realoem.com/bmw/showparts.do?model=0481&mospid=47933&btnr=33_0653&hg=33&fg=15
