Abgeschickt von Martin am 17 April, 2007 um 22:57:39:
Antwort auf: Compression ratio von Matz Rosenquist am 17 April, 2007 um 22:40:51:
Hi!
Do you have a 1ooo ccm or 800 ccm. Anyhow, it may be possible to use pistons of other models who had a higher compression ratio. I think the early 800 ccm engines (R 80/7, 60hp!) or the ones from the early R 1oo RS (if it is a 1000ccm engine) had that ration of 9,5.
It may be necessary to take them togehter with cylinders. I'm not sure about that.
Greetings
Martin
