Re: 1043er braucht etwa 1l Öl auf 1000km
Abgeschickt von Matz Rosenquist am 28 August, 2002 um 14:26:25
Antwort auf: 1043er braucht etwa 1l Öl auf 1000km von Matthias am 26 August, 2002 um 20:31:25:
Hi All!
I recentlty imported a Q-Tech prepared Basic from Germany. It had 9000 km's on the clock and used roughly 1,5 liter per 1000 km's. I was alarmed but kept riding and now, at 26.000 km's, I'm down to less than half. At first the plugs were glazed but after consulting Rudolf Kallenbach at Q-Tech I changed to different plugs, set the timing right and swapped jets from 2.66 to 2.68. Still the lefthand plug shows some glazing but not much.
Not much advice, just a tale from from life.
Rgds
Mr MR
BTW, the engine is really nice-running!!!
