Abgeschickt von volker Sandner am 10 September, 2004 um 13:32:50
Antwort auf: Adding a second brake disc on a R80G/S von Ben Gueroult am 09 September, 2004 um 23:43:54:
Hi Ben,
it is possible to fix a second Braking Disk into a G/S Fork, I used a second Disk from a r100CS made an adpting plate from the disk to the front axle and fixed a second caliper also from a R 100 CS on the left side, there you must also fix adapters on your own. In addition two braking pipes an a change of the braking cylinder to 13mm and it works. Costs about 400€. There is not much space in the G/S Fork, use it.
Volker
