Abgeschickt von r@iner am 22 November, 2000 um 18:27:02
Antwort auf: HPN 43 l tank von Jakub Dvoracek (CZ) am 21 November, 2000 um 16:14:00:
If i'm right the nylon paintable one is just available in white color. So if your tank is white at the inside it should be a paintable one - but i think in this case you would have realised it allready. If it is black at the inside also, i would assume that it is a nonpaintable poly tank.
regards Rainer
