Re: Clutchhandle
Abgeschickt von mike am 13 Mai, 2009 um 21:42:00:
Antwort auf: Clutchhandle von Matz Rosenquist am 13 Mai, 2009 um 11:10:57:
Hi Matz,
I have an additional metalpiece which works as an enlargement at the gearbox holder.In case you need a picture...
BR
mike
: G'day All!
: I'm slowly (very slowly indeed!) converting an old G/S to an HP(n) and I've now run into a question regarding the clutchhandle. I want to replace the complete original unit with switches and all, and would like to replace it with a simple motocross/enduro-style handle.
: Which unit should I use?
: So far I'e tried a couple of standard handles but they have the same result: Not enough travel of the wire to free the clutch completely when changing gear.
: Kind regards
: Mr MR
