Abgeschickt von Joerg am 30 Juni, 2009 um 13:07:17:
Antwort auf: Re: No von AliBaba am 30 Juni, 2009 um 12:22:32:
Hi again,
: It might be the same leak but I think it’s smart to change both the seal and the o-ring.
My local BMW dealership definitively recommends to change not only the crankcase seal and its associated O-ring, but also the O-Ring of the oil pump and the Simmerring at the entrance of the gearbox. I agree, since these small parts cost much less than the crankcase O-ring ... and it's certainly embarrassing to have to disassemble the whole drivetrain and to rip the gearbox off the bike for a part that costs a few cents ...
(... who said "gearbox hairpin spring" ... ? ;-)
: I have checked my factory-manual and as you say it doesn’t mention sealing-compound. The clearance between the cover and the rotor should be very tight (0.025-0.070 mm) and I’m afraid that the sealant will mess this up.
AOL ... I mean, "mee too" ;-)
: What makes me wonder is that I trust Motoren Israel and I’m not sure if they did it by mistake or if it was for a reason.
Would be interesting to know ... there is no reason why a properly installed O-Ring would not do the job. And I don't want any foreign matter in an oil pump :-)
: Arrghh, I’m leaving on Monday and I don’t want an oil-dripping trip.
That still leaves you 5 full days. In that time you could still overhaul the heads, gearbox, and the final drive :-))
Cheers!
