Re: macht nix
Abgeschickt von Marcel am 12 Februar, 2002 um 09:59:03:
Antwort auf: Re: macht nix von stefan am 11 Februar, 2002 um 19:02:06:
: thats interesting, possibly the oil flow at the filter cap, the flow through the cooler and the flow through the bypass is different at different oils, possibly the bellray oil is more liquid at the working tembereature tha the "hot oil" and you have mor flow trough the cooler circuit and this can be the reason for the lower temperature.
: regards muhgruss stefa
My bike doesn't use a oil-cooler.
Maybe these oils do a better job at loosing their heat, I don't know i'm not an oil engineer.
How many miles did you drive your bike ?
