Re: Floating cast steel brake disc 260mm for R 80 G/S
Abgeschickt von hansen am 13 Juni, 2004 um 19:12:03:
Antwort auf: Floating cast steel brake disc 260mm for R 80 G/S von Fabrice am 13 Juni, 2004 um 12:44:11:
: I am looking for somebody who put this brake disc from HPN (804.3)on his motorbike to know if it gives a better braking and if it is easy to instal this one on the original aluminium carrier of the R 80 G/S.If it is possible i would like to have a photo of this disc .
: Answer me in english or french I do not speak german.
: Thank you a lot.
Hi Fabrice,
if you don't get positive responses on your HPN request, you can try EBC floating discs. They come ready to fit, and with the original EBC sintered brake pads you get a much better performance than with the BMW OEM brake configuration. I've got one of these discs on my G/S, and I'm very satisfied with the performance.
Try www.ebc-brakes.com (not quite sure about the correct spelling...)
regards
