Abgeschickt von AliBaba - HPN661 am 30 Juni, 2009 um 10:06:25:
My engine block was overhauled by Motoren Israel a few years ago. The oil-pump also got resleeved (http://www.motoren-israel.com/product_info.php?info=p297_Oelpumpengehaeuse-ausbuechsen.html)
Lately there has been an oil-leak and it is hard to see if it is the crank-seal or the oil-pump o-ring so I decided to change both.
When I removed the oil-pump cover I saw that Motoren Israel had used a thin coat off sealing-compound (and the o-ring). Is this recommended?
I tried to call Motoren Israel but they have vacation for a long time.
