Re: macht nix
Abgeschickt von Marcel am 11 Februar, 2002 um 15:56:50:
Antwort auf: Re: macht nix von stefan am 11 Februar, 2002 um 15:43:10:
: Hi Marcel,
: thank you for your response
: : : das ist die normale temperatur bei autobahnheizen. das kannst Du so lassen.
: : DIDI
: : Are you sure the engine isn't running too lean ?
: the engine is running perfect
: : No air-leaks ?
: no air leaks
: : Ignition timing o.k.?
: yes, it is ok
: : I think 150 degrees is too much, at what speed you're riding ?
: >160km/h, 140-150 is OK; 160°C is hard, >165°C you should change the oil after 3.000km
: : Which oil you're using ?
: normally mineral oil 15W40, but if I drive the GS without oilcooler I chose 20W50
: : Maybe you could try a different brand, like Bel-Ray EXR 20W50
: the cheapest oil (no synthetic) which fullfill the bmw-requirrements is ok for the 2V engine and most economic;
I noticed a lower oil temp with Bel- Ray EXR 20W50, i had the same with Kendall GT-1 20W50; 10,15 Degrees C.lower temps. No i don't work for them !
Regards
Marcel
